FrizzleFried
- Oct 7, 2004
OK...so I will soon spring for all that is necessary to go PCIe...I plan on purchasing a CPU, SLI MB and 7800 GT. I have a few questions...
#1 Would I be better served picking up an Opteron 146 that seems to be the rage...most seem to hit 2.9-3.0 ghz with ease...$150-$165 or so... or would the Opteron 165 DUAL core be the wiser choice...it seems to only be hitting 2.6 or so, but its dual core. I DO like the thought of being able to encode DVD's and play games at the same time... are there games out there that support dual core? The 165s are going for around $290 or so...just about double the cost of the 146s...
#2 What is the best BANG FOR THE BUCK overclocking SLI motherboard out right now? I am looking to keep under $120 or so if possible...
Thanks!
Thanks!
