CPU / Motherboard Issue
anubis
I'm having an issue with my CPU / Motherboard and I'm not sure which is causing the issue.
I had an asus striker extreme mobo and an intel E6600 CPU.
We had a series of power outages and after the 2nd power outage my comp would power up but would not post. The LCD poseter was giving me a CPU INIT error and when looking it up online, I was believed that it was motherboard related. I tested the CPU at one point in another motherboard and it posted / booted successfully.
I then RMA'd the board but when that new board returned, it was giving me the same CPU INIT error.
I decided that I didn't want to bother paying for shipping a 2nd time for a board with so many issues so I went with a different board manufacturer but stuck with an nvidia chipset (this is where I believe my problem stems from). I ordered an EVGA nforce 780i SLI mobo and when it finally arrived on Friday, I loaded everything up and when I powered up the board received an FF message on the board. I received this FF before any other codes were listed. I've looked this FF up online and it seems to be the identical error to the CPU INIT (issues relating to a bad CMOS chip).
At this point I was wondering if somehow my CPU had gone bad. I'm afraid to test it in any other motherboards because I can't afford to keep frying them if this is what's happening. Is there a way that anyone is aware of to test a CPU? If a motherboard is powering up but not posting does that generally mean the CPU or board is dead? If it's the motherboard and I test a good CPU in the motherboard will it short out that CPU as well?
I had the Power Supply tested out and they (local tech shop) said it was fine, I even tried a different Power Supply just to make sure. I've tried multiple sticks of ram, tried a couple of different video cards and had the same problem.
If anyone has any thoughts and would like some additional information let me know and I'll provide whatever I can.
Thanks in advance,
Chris
