CPU + Mobo upgrade
So I'm thinking about upgrading my motherboard and CPU soon. I can't really ask for a specific CPU recommendation, because I might end up buying some used unit, but I'd like to know what chipset I should go for. 1150?
And then from there, which motherboard specifically should I get? I don't intend to overclock. No real special features necessary. Here's the list of possibilities: http://www.hinnavaatlus.ee/products...df70f90472e8faf4fadc939&Order=MinPrice&Sort=0
(There's filters on the sidebar to include other chipsets)
Current setup:
MOBO: Gigabyte GA-b75m-d2v,
CPU: Intel i3-3220,
GPU: GTX 960,
PSU: SeaSonic S12II 620w,
RAM: Crucial Ballistix Sport 8gb
Case: Corsair 200R
Why are you upgrading your CPU and Motherboard? What do you do on this computer that the current setup isn't capable of handling? What kind of budget do you have?
