CPU/Memory ratios?
VitalSign0
Can someone explain this?
Example. I have a 1.6ghz processor @ 400FSB. The multiplier is 16. So setting the bus FSB @ 100/33 gives me 1600ghz. Makes sense.
My memory is PC2700(166mhz). What should the ratio be set at and could you explain what logic you use to get to that figure?
Thanks.
