CPU Lni.
jakethesnake011
Please help
The last 1 days I been changing some things in my comp. I have an MSI Eclipse mobo x58 and a i7 920. Now I went to change the chipset, north and south heatsink and put a thermalright Hr-05 sli on but they do not fit. So I took them off and put back the old ones. Now the old one's had some plastic on the underside where the chipset set in. I took the plastic off and then went to clean the old thermalpaste, and the thermalpaste on my chipset. I then added AS5, I was careful and made sure none got on the transistors, I check twice and none was even close. Help please I keep getting a error of CPU lni. Cpu initiate failed error and I do not know what it could be.
Did you unplug anything at all? Have you done a RESET/CLEAR BIOS yet? I'd say try that first and see if you get anywhere. Also reseat the CPU, memory and video card.
AS5 is electrically conductive. You have some paste where it doesn't belong. Get out the rubbing alcohol and start cleaning your motherboard. Change the title of the thread and you will get a better response.
