Due to the awkward angle of my Lian Li case, I have a limited choice for a heatsink fan.
For my HSF, I chose a Thermaltake V1.
However, the measurements were off (the W and L were switched around) and now instead of the HS fan blowing away from the intake part of my case (and towards the front of the case, near the optical area) it is now blowing up and towards my backside of my 8800GT.
TL;dr: Will this heated air towards the back of my 8800GT hurt it?
I am planning to install my Accelero S1 on my 8800GT once everything else is set up
here it is, what space i have to work with.
case fan next to it is intake, i guess i can mod it to be out, ill just need somehow to mod then the front unused optical bays somehow to accomodate a fan, as ive seen in some others builds with mesh in front... how does one go upon that?
or does anyone think they have a sure-fit hsf combo that might fit?
