ScarsUnseen
- Jul 9, 2007
Hey all,
I have an AMD Athlon 64 X2 5200+ cpu on an MSI MS-7325 mobo. I'm NOT overclocking. It's summer, my computer is running extra hot, and I pretty much use my computer as my sole entertainment system. Before upgrading my CPU fan, my average temperature (from CoreTemp) with the stock fan would be about 55-60C. After upgrading to the Thermaltake Ruby Orb CL-P0391 fan, my temperature is about 67-70C. I double-checked my application of the thermal past and it should be fine. I'm using the thermal paste that came in the fan's box, NOT Arctic Silver 5. I just ordered some of that online and should get it soon. Any suggestions otherwise?
http://www.tigerdirect.com/applicat...CODE=GOOGLEBASE&cm_mmc_o=VRqCjC7BBTkwCjCECjCE (link for reference)
Here are my system specs:
AMD Athlon 64 X2 5200+ Windsor (2.61GHz)
MSI MS-7325 mobo
8GB DDR2 PC2-6400 RAM
ATI Radeon HD 3870 GPU
550watt PSU
I would also like to upgrade my CPU itself eventually, so I could really use any suggestions on cooling. =)
Thanks,
SU
MSI MS-7325 mobo
550watt PSU
Thanks,
SU
