CPU heatpipe heatsink in Tower case...
Soyo13
The heat are evaporated to the top of the heatpipe right? Woluld't using heatpipe heatsink on mainboard that are stading vertically affect the preformance?
Current heatpipe technology works fine independently of the orientation.
I had the same question before i bought my current cooler (should be in my sig)
I had read a review at mad shrimp (i think?) and he had tested it only with the mobo flat on the table
I asked him to test it again with the mobo verticle and the temp changed ~1-2C minimal change
so, in the end, it really doesn't matter :)
It doesn't really matter. The only time it would, is if it's the one-way. normal heatpipes have a wick in the middle all the way from the top to the bottom. The one-way's only have t he wick most of the way down. they will work better, but they only work in one direction.
