noteworthy
- Jun 6, 2004
Well my first install was great.... no leaks at all...
So after I took it apart and put it in a new case. The tubes weren't as tight (clearflex 60) so I bought some metal clamps to hold them down. I thought I had them all tight and when I filled the system water dripped on to my vid card like a running faucet. The gpu also leaked. I removed the cpu block off the cpu and tightened it. I dried off the mobo and graphics card and let it sit about 36 hours before I powered on teh system. It booted up fine the first time then it rebooted by itself.. and when it went back into windows again the screen was all screwed up. DOS prompt and boot text is perfect but the windows GUI is all wacked out. Opened my case again and found the cpu barb/tube leaking very slowly. I've cleaned off the card with alcohol and let it dry for a bit.
How long should I wait till I can power on the system again? I don't think the card is fried because it'll boot into windows then reboot and lockup the second time. Also the boot text is perfect... Just gui is messed up.
