Hey all, just two questions:
1) I'm currently using a ZALMAN CNPS9500 on my CPU, but would like to change to another cooler/sink that allows for changing the fan (such as on some of Scythes), that way A) if the fan ever dies on the Zalman, I'm not stuck and B) can have something that maybe cools a bit better, again, including the ability to change fans to aid with that.
I run an Intel 975 "Bad Axe" (775, T) with a P4 3.6... suggestions?
Can't seem to find anything I'm sure will keep it cool and/or not get in the way of anything on my mobo.
2) Would a 28cfm fan be enough cooling on a Thermalright HR-03 that's on my GPU (ATI x1900xtx) right now?
I have a temp controlled 92mm on there now, but it's rather loud, especially when hitting 3100rpm.
Under load, I don't even hit 60C now, and I was hitting 90-100C with a Zalman on there, so I'm wondering if the slightly slower (and quieter fan) would be alright.
Thanks & cheers.
Thanks & cheers.
