Hi, i have a e8500 on an asus p5q pro. I do not plan to overclock it, right now I am running or at least am trying to run at its rated speed. A few questions:
1.I just mainly want to know how I can check whether or not if i have a fsb of 1333mhz? It seems its running at 3.16ghz, so thats good.
2. When I enabled intel speedstep technology, the cpu ran at 3.17ghz when the cpu usage was 0%, i know this by clicking ctrl alt del to check usage, and right clicked "my computer" in windows to properties to check the cpu speed, as per intel website instructions. I thought speedstep technology brought down the clock speed when its wasn't required to reduce heat and power usage? Then i disabled speedstep, and it was running at the same speed as before. Anyone what might be the problem? would u recommend speedstep tech.
3. should i disable intel c-state, it was originally disabled. IDk what its for
below is a picture of cpu section of the bios. srry its so unclear
i applogise for all these newbie questions/ Thanks
