CPU Frequency settings in BIOS
fubak
I just got a XP3000+ Barton and I need to know what the following settings should be...
Spread Spectrum
CPU FSB Clock
CPU Ratio
CPU Vcore
Please help quickly!
The FSB Clock setting will only go up to 220MHz?!?!
werent the xp's fsb's "double pumped" so 220 is actually 440 which is 40mhz over stock
fubak said:
I have an MSI KT3 Ultra 2 if that helps...
doesnt the xp3000 have a 400mhz fsb if thats the case then set the fsb to 200 if it has a 333mhz fsb then set it to 166
fubak said:
What does Spread Spectrum do?
turn it off...it can cause stability issues. not usually but it can and it offers no performance advantages so you might as well leave it off
Thanks for the help guys! I cleared my BIOS and reset all the settings and it's working fine.
Spread Spectrum
CPU FSB Clock
CPU Ratio
CPU Vcore
There are 2 models...
Which one do you have?
http://139.95.253.213/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=13,E=0000000000139784485,K=3942,Sxi=15,Case=obj(1224)
The 333Mhz one
