CPU for around $100 and below.
TuxedoBond
It will be used for general purposes as well as high definition video and audio. I will be using an after market cooler for it and will be over clocking, so if there's a good overclocker in that price range that would be a better value after its overclocked let me know.
Motherboard is a Biostar TA790GXB A2+.
Agreed. The 550 is an awesome dual core processor that can be overclocked to nearly 4 GHz!! If you could spare $20 more, Id suggest getting the Phenom II X3 720 for $120 shipped at Newegg. Its a tri-core proc that is also an excellent performer. Its $20 more but it will future proof your rig a little longer.
I second this. The 550 is a good choice, but the 720 will give your rig a little extra spunk and won't be obsolete as soon.
I just ordered that 550 myself- $102 w/free shipping from the 'Egg. It's probably gonna be a temporary for me till the X4's come down in price, but I'm looking forward to seeing what it can do. Heck, if I can unlock it, I won't even have a need for an X4! Plus, I've read some great reviews on it. I'll be using it pretty much for the same purposes you are.
This PC is for a person who wouldn't make use of the extra power any way. It just needs to play hi-def video and audio and do the basics fine. So I think the 550 will be fine unless there is a huge difference in the stock performance or overclock ability between the two.
How about between the 550 and the 710. Which overclocks better and which is better at stock?
if its just for HD movies and normal every day stuff.. go with the athlon II x2 250.. since you can use a nvidia or ATI card to do hardware accel.. you dont need all that much cpu power to play the movies..
the 550 easily overclocks better.. 710 has the locked multiplier.. the 550 doesnt..
the 550 sounds like overkill to me
it sounds like this pc is gonna be a mom/pop internet browser / media machine, hell if the user doesnt multitask very heavily you vould get away with one of those new sargas semprons, although a dual core cpu would be nice, i'd say get a athlon II X2 something or other. The 240 goes for 60 bucks at the egg, that will save you 40 bucks...
Does the 710 perform better than the 550?
your comparing a tri-core to a dual core.. they each perform differently depending on the application and OS you use..
but like i said in my last post.. an athlon II x2 250 is the best processor for the price to performance ratio to what you plan to build.. and yes it can be overclocked to 4ghz as well depending on the memory you use..
Picked up a 720 a week ago and I'm up to 3.8 ghz on air. 16.5 multiplier / 230 mhz fsb / 1.4 v to the chip.
Solid as a rock. I haven't had much time to tweak but I'm sure I could get more out of it.
