CPU Fan Speed. Is this normal?
jediado
According to nvidia ntune, my CPU is at 50 celcius (this is at idle) and the fan is spinning at 1180 RPM. Is this a normal speed? Should it be going faster than this? And if it was lower than this, how bad is that?
I was trying to play City of Villains and I checked my CPU fan speed and it was at 950 or something and the game was most definitely not running smoothly at all.
I've got an EVGA 122-CK with the E6750 and 2 XFX Geforce 7800s with 2 gigs of ram. CoV should not giving me problems. I was getting artifacts at one point. The game will start up quickly, once I'm in, every 5-7 seconds it hiccups or hitches and it feels like I'm lagging.
What mobo do you have and is your CPU fan-speed controlled by the mobo perhaps? If so disable any speed control and set it to 100%.
yeah your CPU is idling a little hot but artifacts point to GPU problems.
Looks to me like the whole system is gasping for air. Whats your case, and how many/what kind of fans do you have on it? so long as the answer is a case with an intake and an exaust, and that intake and exaust are filled, your cpu should be idling 45C max. --which is another thing, whats your ambient?
