"CPU fan failed" says the POSt reporter
pbXassassinX1524
okay, in the system in my sig, I just went and enabled the ASUS Q-fan function to see how well it works... well, it makes my system much quieter accept, whenevr I boot/restart I get an error, and the POSt reporter says that my CPU fan failed.
well right now I'm running prime95 with no problems. the fan speed is about 1670 RPM (when it used to be like 2460, or something close) and the temps all look good (47C on load, only like 5 degrees higher then when I had it w/o the q-fan. so does anyone know why it would be reporting that the CPU fan failed?
It's the stock HSF that comes with the 3.0C
Is the RPM monitoring fan plugged into the motherboard or an external RPM monitoring device such as a fan bus?
more than likely if you don't have your cpu fan plugged into the 3pin connecter right next to your cpu, it will think there is no fan.
Ah yes, I didn't think of that. Make sure it's plugged into the fan header marked "CPU" and not "CHA" or "PSU".
yea its plugged in right... if it hadn't been, i would suspect it would have done this from the get go. What I got in my other thread was that its kind a bug in the SiS/ASUS mobo, where it detects that the CPU fan speed it much lower, therefor thinks its failing. All I need to do it alter it so it doesnt read it like that. Just have to figure out how.
Well
I ran AbitEQ and when I turned my fan all the way down, AbitEQ set off the alarm and then shut the computer down (Needless to say, I no longer run AbitEQ).
So, what you need to do to prevent this is go to your absolute minimum speed, and then up one notch.
At my lowest speed (1530RPM) most hardware monitors see my CPU fan speed as 0 or 600. But if I bump it up one notch, bam, 1560RPM on the nose.
So it sounds like you have the same issues I did.
I've seen fans that when run at low RPM's would occasionally "glitch" and indicate 0 RPM even when it's obvious that they didn't stop; like the case fans in the wife's computer, for example. I had to disable RPM monitoring on that fan; not sure of any other way to get around it.
Good Luck - B.B.S.
alrigh what I had to do was go into the system monitor in the BIOS and set it to ignore the CPU fan speed. No more error!
thanks for the input.
....only issue with doing this on a CPU fan is that if it stops......:eek: :eek: :eek: ...and you won't know it until the fire truck shows up (OK, maybe not that extreme but you get the idea)...
Good Luck - B.B.S.
well, if it made it to windows before it burned I would know. Because I have the ASUS probe running almost constantly to check temps and what not. It has an alarm that goes off when the CPU fan falls below 600 RPM :)
