cpu exchange
bond9229
Now I bought a Dell Inspiron 5150, ya I know big mistake, but I complained enough and they are exchanging it to a Inspiron 6000 after almost 2 years, haha with another 2 years of complete care warranty. haha
anyways my question is, on the old hunk of junk, i had a 3.2ghz P4 w/HT and on the new comp i am getting a Intel Pentium M Processor 740 (1.73GHz/2MB Cache/533MHz FSB)
Now is this a fair trade, and honestly i do not care about it being more mobile and more battery efficient, is it a better cpu, plain and simple.
Thanks
The CPU is a lot cooler, and yes, it is better.
Would be amazing if you could overclock it and get some excellent performance, but Dell motherboards don't allow o/c.
The P4 with HT @ 3.2 is probably a bit faster.... Yes the Pentium M is a lot cooler, and gets better battery life, but if you don't care about those things...
The big thing you are losing is HT. Multitasking suffers on Pentium Ms, I have a Pentium M laptop myself @ 1.6. While it is nice for battery life, and has plenty of power to get most stuff done, my P4 system at home does feel a lot snappier.
Maybe, maybe not. I have the same Pentium-M chip in my 9300. I sold my P4 2.4Ghz 800FSB w/ HT and stayed with this and didn't notice a difference between the two. The only time I do see a difference is in HD access. That's my own fault though for going with a 5400RPM drive instead of a 7200RPM drive but I couldn't justify $300 more on the price for a few more RPM.
I have a 3.2E and a 2.8C and never notice a difference between HT or not. It's not as beneficial as they make you believe.
If you overclock that CPU, wou will kill almost any Intel CPU out today.
How much of that is the processor and how much is Dell's bloatware? That and your desktop rig has HT, of course a single core lappy is going to feel intangibly slower coming from quasi-SMP goodness. Doesn't mean the raw speed isn't there.
Well, its a Latitude line notebook, so minimal bloatware. Also, I guess I said it confusingly, my desktop rig doesn't have HT either, it's an original run northwood 2.4, however, it's still faster than the 1.6 Banias in my laptop. I have used HT enabled rigs, and those seem very very smooth, not quite dual core smooth once things get hot and heavy, but still very nice.
what i have heard is that the pm cpus add aprrox 1-1.2ghz to be measured alongside with the p4s ht. so a 3.2ghz p4 with ht would be equal to a 2-2.2ghz pm??
is that a fair assesment, or I totally out to left field on this one.
thanks
Um, they both have Hyperthreading.
OP, they've already said it. The M is just as fast except for HT.
And you can disable Hyperthreading in the bios. I don't notice any difference when it's enabled or disabled.
There's a difference between M processors and normal S478 processors. They're a lot faster when overclocked and their power usage is amazing.
Especially in a laptop, I'd go with the M processors because those laptops are a lot thinner than the S478 Northwood/Prescott laptops.
The Inspiron laptops are nice, just get 1 Gig of ram and you'll be more than happy.
because I have a friend who has the 6000 and it's really nice. I would get one too but I would go high end not 6000. Don't get me wrong though, I like the 6000, it has a nice sleek look to it and it performs really well. I would recommend you upgrade to 1gb since 512 doesn't seem to cut it nowadays. Other than that, they're definitely worth the money. :D
man i got the new cpu today and it is a lot slower then the old one. new one being 1.73 pentium M compared to the old one being a pentium 4 mobile 3.4 with ht.
Whenever I play a game the cpu runs at 100% the entire time. oh dell....
Um... ya... Ive never been on any computer that doenst use the processor when playing games, unless of course you are talking about solitaire.
The P4 with HT was the reason it wouldn't appear to be running at "100%" because it imitates two processor cores - and since most games aren't multithreaded, they only make use of one theoretical core. This means that when the CPU isn't Hyper-Threaded, it will run at 100% CPU usage for that game - it's a dedicated program and a game needs the processor in its entirety. (For a HT CPU, it will run at 50% - or one theoretical processor maxed)
You'll definitely notice at times that it'll feel slower - but the performance is there. It also runs a lot cooler while using a lot less energy - it's a very efficient processor, so don't feel discouraged. You've got a good processor in your hands.
