cpu / dram on cpu z
basically what i wanna know, is this good or bad.....
fsb / dram : cpu/22
on cpu z mem page
i'm running a 3500 @ stock
corsairxlpro 3200 (2.2.2.5)
it seems to be running @ timing, but if that 22 means its running at half of my 11x fsb multiplyer, that means its a cpu 1 / dram 2 ratio, right?, and thats bad - if it is, how do i fix this
i have stock cooling, but with as5 instead of that crappy thermal pad (was planning on watercooling but couldnt afford it in the end) - anyhow, without buying new hardware - ie watercooling or a new fan, can anyone help me make this better?
or explain how to get a decent overclock, etc - ie what bios settings i should use
mobo - a8n-sli -d
computer seems fine , but if i can get more out of it, why not.....?
