Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Because i'm doing an overclock and because i've read in some places that overclock can make cpu degradation with time, i would like to know from you what can cause that? high vcore? high pll? what?
Voltage is the only major factor in CPU degradation. Heat, unless excessively high, will not harm a CPU, since they are designed to withstand significant temperatures. With a 45nm CPU like your E8400, you should keep the CPU voltage at or below 1.4V at all times. With a 65nm CPU, such as a Q6600, the voltage should be kept at or below 1.5V.
