Have a X3 720 BE that I can get to 3.4 at stock voltage and is stable.At 3.5 the machine will boot into vista and hang(mouse works nothing else.) The core voltage is around 1.4. In the bios there are 3 options .50mvs,100mvs,and 150mvs.I have added the voltages up and it appears that the max is 1.5 volts is this correct and will it have any serious side effects? Heat does not seen to be a problem.
Specs in sig.
Specs in sig.
