cpu cooler question
1 and 4 would be an improvement over stock cooler at stock speeds but wouldnt be that good for trying to oc. #4, is probably only about as good as the stock cooler, just lower profile. so yes they will but only at stock speeds.
so how would this do at stock speeds? https://www.amazon.com/Enermax-LIQMAX-Performance-Liquid-ELC-LMR120S-BS/dp/B00QWZIN9W its what i have and IF i can save 100 bucks and still use it id like to BUT if you think it would be BETTER tp upgrade i can do that also.
it will be a bit better than the stock cooler but dont expect to oc on it. try it, and if youre not happy with the results you can always upgrade later.
edit: wait a minute. how many of these threads do you have going?! i knew i was having deja vu....
https://hardforum.com/threads/5800x-cooling-question.2004634/
