CPU Cooler Help Needed
mrcountry
HAF 932 AMD Edition
Gigabyte GA-790FXTA-UD5
AMD Phenom II X4 965 BE
Cooler Master Silent Pro
I could really use some help deciding which CPU Cooler to go with. I want something that does a good job and fits well with the setup that I have.
+1 for the 212 as well.
Didn't care much for the direct heat-pipe BS, but it did a pretty decent job.
You should check the FS/FT thread here, you can prolly snatch up a true pretty cheap, i got 2 of the 1366rt's practically NIB for 70$
I'm still a little leary of the h50, not saying its a bad unit, im sure its a great unit, and lots of people swear by it, i just feel that a single 120 rad would put some limitations on your thermal capacity. in my experience if your not ready to go to H2O, some of the better air coolers have more thermal headroom than the H50, but that is just my opinion.
