[21CW]killerofall;1031326114 said:Ninja Scythe FTW as it has 6 heat pipes and it never even gets warm to the touch with my OCed Opteron 165 @ 2.61GHz. If you have good air flow you don't even need the fan. Plus it only costs $40 which gives it the best price/performance ratio for cooling out there. Anyone else out there have one?
Yes (Scythe Ninja Plus Rev. B), sitting on my Q6600 right now, though as I've just built this i'm at the parananoid granny stage and i'm using the fan.
I am still up to some skullduggery about the case with regards to cable management and tweaking, so it's been on and off a few times causing me to see how the heatsink feels and it aint felt mildly lukewarm, nevermind hot, when i've touched it.
I read a review of SCYTEH SCNJ-1100P CPU Cooler; not bad at all. It does come with a 120mm fan. Can the fan speed be adjusted manually or it is adjusted automatically depending on temperature ?
