CPU Cooler for GA-H77N-WIFI?
devonhiee
I just completed my build with a Gigabyte GA-H77N-WIFI in a Cooler Master Elite 120. I purchased the GeminiII M4 but it is so big that, due to the location of the PCI-E slot, the graphics card does not fit.
Can anyone recommend a good CPU cooler that will work with this mobo + PCI-E?
I'm using the prolimatech samuel 17 with that board and it works fine. The new thermalright cooler should work fine too, or the low profile noctua one.
This is pretty much the standard position for the CPU socket in mITX boards, so a lot of the threads in this forum cover heatsinks that should fit fine.
Are you also using the Cooler Master Elite 120? If not, the CPU cooler has a maximum height of 65.0mm / 2.5 inch. I'm thinking its not going to fit since a standard 120mm is 25mm in depth. Once placed on the heatsink, it will be 70mm. At least I think that's what it would be.
I'm using the Lian-Li PC-Q12, which has an official max height of 55mm, but there is about 10mm to spare on top of that. The Samuel 17 is 45mm so it only works with a 12mm fan. And as far as I know Scythe is the only company that makes 120 x 12mm fans, but they work fine for me.
Try to find out if there is any room to spare on that case. If not then a 12mm fan should work fine. I think the noctua low profile heatsink is much smaller and should fit fine, but it's probably not as effective as the bigger heatsinks. And the axp-100 should be about the same height as the samuel 17, but it comes with its own 12mm fan.
The CM Elite 120 can actually fit somewhere in the neighborhood of ~72mm, I'm used the CNPS8000B from Zalman and it did an alright job, won't allow much for an overclock but did great on a 3570k stock clocked - even better if you can undervolt or improve airflow.
It also keeps the PCI-e slot clear and standard sized ram works just fine - you can even change RAM out without fear of having to remove the HSF.
Oh and since it's PWM you can use silent profile in BIOS and let it all do the rest - very quiet.
Thx for the recommendations. I think imma go with the Zalman. Although I like the Samuel, it's gonna end up being almost 3 times more than the Zalman.
tbh you are better off with one of the all in one watercoolers but if you must have air
then maybe a zigmatek preaton + a thick fan. im using the zigmatek with slim fan to cool a A10 5800k and intels at stock clocks wont get hotter then that
Good luck finding that hsf, I wanted to try it for a long time before I picked up the Zalman - honestly don't think it's worth the money from what I've heard - plus if you have to replace the fan on a brand new cooler meh.
