Only the LGA1366 version of the heatsink comes with a fan, so if you get the regular version you'll definitely need to buy your own. The fan you linked to looks pretty decent, although I'm not familiar with it so I can't say anything for certain. This would also be a good option: http://www.newegg.com/Product/Product.aspx?Item=N82E16835185005high end overclocking
i'll tell him to get the Thermalright Ultra-120 eXtreme
should i stick with the stock fan or get something stronger
i'm thinking of getting this fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835220022
noise doesn't matter, but he doesn't want a vacuum in his case. something around $25
also what should i use for securing the fan on the heatsink?
