In earlier days, huge CPU coolers used to fry MB headers if plugged into them. Is this still the case? I've got a hugemongous Coolermaster V10 (two 120mm fans!) going into a Gigabyte EX58-UD5 board. Can this board handle the current? I usually split the fan power wires into a standard molex and plug directly into the PS leads. The yellow speed monitor wire then plugs into the MB by itself for monitoring. Does anyone still do this?
The V10 comes with two leads, one a standard molex which is solely for the TEC unit I believe, and a thin flat 4-wire cable for the MB plug. I assume the 4-wire job is two hots for the fans, a common, and the fan speed signal.
