cpu console client stopped working
wtsamatta
hmm, kind of weird. I had a client up and running fine, then it stopped. Couldn't get it to do anything. Not even configonly. Though that it expired so I downloaded a new mpich smp client, started with install.bat, went fine MPI showed twice, tried to run as configonly in console, and get nothing :( :confused: No information in event logs as far as I can see. q9550, 750isli, vista x64 ultimate
there is a new dropin executable. they may not have updated the installer. there is another thread here, but can't easily on my phone.
Posted via [H] Mobile Device
They really need to tell you that it's expired when the client fires up. I don't see how that would be THAT hard to do. I hadn't run the SMP client in some time and started running it again, I forgot how that when it expires it simply won't run at all. No message, no nothing.
i no longer run the WinSMP client, but I feel the same way. Back when I did run it, when it stopped working I checked here for new exe information.
Thanks. I would have figured that at least the client would have been updated. I know that they expire, that's why I downloaded the client again :rolleyes:
The WinSMP client isn't very well-supported, unfortunately. Hopefully that'll change once SMP2 rolls around.
