CPU Compatibility Help *****
Mmm.vap0r
I currently have a GIGABYTE GA-8I945PL-G mobo with a Pentium D :(
I want to upgrade to a core 2. Could I use something like this?
If not, which core 2 cpu's can I use?
and whats the difference between the Conroe and the Wolfdale?
Please and thank-you for any helpful responses. :)
Oh ya, and the difference between the Conroes and the Wolfdales is that the Wolfdales are 45nm which means that they run cooler and can Overclock higher without getter hot to fast. And the Conroes are 65nm.
