CPU Celeron M / Centrino
Klowinns
Hello,
I currently have a Celeron M CPU on my laptop. Is it possible to upgrade to a Centrino CPU?
Many thanks for your time.
Regards,
Klo
Centrino is not a processor, it is called the Pentium M. Yes, you should be able to upgrade to it, just make sure which chipset you have on your laptop. If its the i855 then you can only use 400FSB, if its i915 than you can use any Pentium M.
acascianelli - Thank you for your reply. How can I see what type of chipset that I have. I can't seem to find my manual.
Thanks again.
I found the Chipset Intel i852GM. Is it possible to upgrade?
Thanks again for your time.
You should be able to upgrade to any 400FSB Pentium M processor.
Sorry for the bother again. Is this what I'm looking for: (Centrino) Intel Mobile Pentium 4-M
Thank you for your time.
Regards,
Klo
No, P4-m isn't what's in the centrino. It's the Pentium M you're looking for... right?
Well, I don't know who told you about a centrino p4...
Oh and you can't upgrade to centrino. Centrino is what makes a laptop thin, power eficent, and other good crap, enless you want to redesign your whole laptop, Just buy a pentium M all the performance of centrino +a tiny bit of weight and a tiny bit less power
Regards,
Klo
You need to find a Pentium M, look for one that is a 90nm (Dothan). Centrino is the name given to the i852GM + Pentium M + 802.11b/g.
If I remember my Intel model number right, you can use any Pentium M 7x0. As long as it has a zero at the end of the model number, that means it is a 400FSB CPU. I would try finding a Pentium M that runs at 1.6+
There is about an ~800mhz performance difference between Pentium M's and Pentium 4's. So a Pentium M at 2.0ghz is somewhere between a Pentium 4 2.8-3.0ghz.
7x5's are 400FSB chips, 7x0 are 533FSB. His options are up to a Pentium M 765 (2.1Ghz). Though he'll pay through the nose for one. A Pentium M 745 might be more reasonable.
edit: What model is your current Celeron M Klo? Are you looking for just more performance and/or more battery life?
Hello,
I want to send an additional thank you for the help that this thread (forum) has provided me. I received and upgraded the CPU and all is running great.
Thanks again,
Klo
