- Dec 19, 2005
Here it is running
Whoa, you mailed it to some guy in Russia for (presumably) a reball? How much did that cost?
It's nice to see you were able to fix the FX5800Ultra ES card and having it run without artifacts. For ES cards it's not uncommon to have issues because they may have been tested to the breaking point while in the development stages.not sure if i posted about this, but i noted several differences between the ES and Retail cards...
Depending on what ES card you're using a basis there can be a wide range of differences when compared to production cards.
Another difference between the two cards you're comparing is that the production pcb is Made in China while the ES one is most likely made closer to where nVidia had their labs in the US.
I have some early samples as well. From left to right FX5800U ES w e-tag, FX5800U ES no back plate, FX5900U ES protoype cooling & e-tag, FX5900U ES w TV-tuner, FX5950U ES with nVidia logo backplate
The one with green FlowFX having no cooling for memory at the back because nVidia engineers soldered test wires at the back for probing and it's currently having the same artifact issues as yours did. I don't plan to fix it as my other FX5800U is working just fine.
We are going to need a higher resolution copy... for.. you know.. research purposes or whatever.![]()
Got some history information on this card:
New message from: miles556 (203)
It is ... i absolutly love FX series cards. I was college student when it came out & empty my credit card & partially my student loan to get it to enjoy playing doom 3, farcry. I managed to beat both games at 1024x768...nothing felt better on this planet than beinf in those games. I'm 34 now and kept this card with me to hold on to my memories. But card somehow start having issues after sitting in plastic bag for 15 years
i wanted to emphasize the difference in build quality of the backplate a little more accentuatednot sure if i posted about this, but i noted several differences between the ES and Retail cards...
Essentially the backplate is quite different...
The Retail card has a "cast copy" with obvious textured surface and a notch out of it...
This is the ES, looks a lot better and completely smooth IMHO: less chintzy:
I also noted that the Slot mounting bracket to the case is different. The Retail has an extra random stand off and also one additional exhaust vent.
The other differences are the ES has hand writing on the Cap of the Die indicating "43" and also some hand writing toward the front of the card on the back.
