couple questions for Fragbox 2 owners
n00btard
1) Is the top handle removable? I'd like to watercool it, and I'm planning on using an Asetek Waterchill Xternal for that purpose
2) How much vertical clearance is there between the CPU socket and the power supply?
3) If I use a power supply with a sh**load of cables (such as my OCZ Powerstream), then is it possible to hide those cables, or tie them off to any support beams?
4) How rigid is the case, once everything is bolted down?
1) Yes you can remove the handle, but I have never done it before so I don't know how easy it will be.
2) I'm not sure of the exact amount but the Silverstone Sugo is pretty much the same thing so look at that.
3) It's quite hard to hide the cables. I use my spare external 3.5" spot, but you have to buy a cover for it because they were cheap and didn't include any. Also if your using 1 hard drive you *could* run cords underneath that hard drive, by installing it in the higher spot.
4) Well I feel it is much more rigid than say a Q-pack in my opinion. I have never liked the flexible top but once it is all screwed down and components are in it feels nice and sturdy.
Another thing is the top is slightly hard to get on at times. Mine takes a little wiggling to get on right, but in the process it scratches the hell out of the aluminum. Fourtunatley it is in spots where the window can't see. If i knew about that, and that its not the best in the heat department before I bought it I would have never paid 300+80 shipping for it. But you are watercooling, so heat is not a problem, and it is a very sharp case in my opinion. If I was building another SFF, (which im not due to limited motherboard choices for conroe) I would buy a shuttle or Sugo. Plus after my huge frustration of getting NV4_Disp error, I want to give Ati a shot. Well you have my opinion good luck
;) and post pics when your done water cooling.
Once I manage to get the case and the kit though (I have the money, but mom wants to use it to send me to Japan to work so I can earn back maybe a third of it), the Waterchill unit is roughly 19" long... and the Fragbox 2 14" or so... so that'd look really weird with some thing that's longer than the object it's cooling straddling the case :eek:
you will not be able to watercool it internally, the fragbox is even shorter in length than the sg01, and it only has one 5.25 drive. good luck.
