grandpatzer
- Feb 24, 2010
So after some work and time I finally have completed the watercooling and this time no air pockets in pump
2 questions that worry me:
the 45 degree danger fittin or what it's called is bending badly, normally the middle cut part that is supposed to rotate has no space but because of tension in tygon tube between reservoir and pump actually bending it, it looks like it could start to leak any point.
is this something to worry about? pictures can click to get fullsize.
Also here is the final build, in 2-5 weeks I will also watercool my 7970 I also own another used rad it is 360, I'm considering drill out harddrive cage and dremel some dvd cage to have 360 rad in front, or I will get radbox and but it in rear.
