I just finished my first build. Originally I only had a single HDD in at (120gb Samsung) but I just now installed a second drive (500gb Maxtor). This is my first time using a system with multiple HDD's, so I had a question. First, when installing games, software, etc. do I have to install it to the drive with Windows installed or does it not matter if I install it to the other?
My second question isn't really much about the HDD as it is about my case's HDD bay. When I received the HDD in the mail, it was OEM (I thought it was retail) so it came with no screws. I just figured the screws were the same size, so I just used some extras I had from my first HDD. Well, they're too small but now, the small screw won't come out. If I use a screwdriver, it just spins in place no matter which direction I turn it, but for some reason, it won't come out. I've tried using a jeweler's tool (the thing with 3 retractable prongs) to grab it and pull it out, but it will only lift so far (and kind of at an angle) and won't budge. I've tried getting to to just fall out by lightly shaking it, but it won't. This is why I hate screwing HDD's in
I want rails! Anyone have any suggestions? I currently have it secured with the one bad screw, and then three larger ones that are apparrently the right size.
