ETH mining is heavily memory bandwidth bound, to the point that incremental compute horse power doesn't really matter.
After some experimentation, here are my settings (for NVIDIA) that could make mining more "green" and prolong the life of your cards.
1. Set the power limit to 50-60%. This will decrease the GPU clock to about 1000 MHz, without affecting the memory clock. Mining speed degradation will be less than 5%, while your power bill will be cut to about half and your GPU will last 10x longer. My 1070 FEs are running at ~60 degrees Celsius and 0.8V core with this (from 82 oC and 1.05V).
2. Overclock the memory by 5-10%. Memory clock is proportional to mining rate.
In Windows, use MSI Afterburner, while in Linux, use the NVIDIA SMI tool.
I am currently getting 81 MH/s from 3 cards on Windows. Hope this helps!
