couple case questions
mr_prez
can i put an atx motherboard into an apple case? does anyone know a wholesaler that sells just the cases?
No, you can not
And you cant buy one, you might be able to find one on eBay though
Apple motherboards are not ATX motherboards, so a bit of ingenuity will be required.
Just get the Lian Li PC6070, it sort of looks like an Apple G5 case. I will get that case one day damnit!!!! Soooo expensive tho, why??
Er, the 6070 looks absolutely nothing like a G5 case, aside form the fact that they are both made of aluminum.
Did not say that it looks exactly like a G5 case, but what other PC based case looks like the G5?
I was just saying that it looks simple, sleek, and to the point.
yah, but i wanted the g4 because it folds down the motherboard on the side....you guys know any other cases that can do that?
don't know of any other cases that do that but if you put the time and effort you can make an ATX fit or you could mod a PC case to do the same thing
sometimes an apple case goes up on ebay i think theres one on there right now
Even with the Quicksilver or Digital Audio which have 5 expansion slots instead of 4 you're still, due to layout, most likely stuck with a mATX motherboard. It can be done, I have a Digital Audio case sitting here that I'm going to do SOMETHING with just not sure what yet.
