2560x1600 max everything, 8.8's,
just check the AA and its OFF for the 200+ fps
pic 3 is 2x aa @ 150 fps
4x aa, even edge detect drops down below 30 fps, yet looks no different than 0 aa
not thinking you can tell the aa at this resolution
for some reason the ingame screenshot wont work with 2560x1600 rez, something about a file size error, so using print screen and pasting it into paint, the colors are washed out
didnt seem to loose much fps going from 1920x1200 to the 2560x1600
0aa
0aa
2x
0aa
0aa
2x
