Counter Strike 1.6 eyefinity?
Merko
Hello.
Can you use 3x24" (1920x1080) eyefinity in Counter Strike 1.6, or the Half-Life 1 engine?
I've tried to search some, but i coulndt find any CS 1.6 in eyefinity.
Would be really awesome if anyone could post a screenshot of your monitors with eyefinity, or just ingame-screenshot. If this is even possible.
Appreciated. :)
I really have no idea, but I'm pretty sure eyefinity works at the dx level, so I'm guessing it would work fine. Only question I'd have is if the 3x monitor resolutions will show up in the options, or if theres some way to set it, and I'd guess there is. No info to back any of that up though, sorry.
Thanks anyway. Gonna cross my fingers on it :)
In Options there is no Aspect ratio settings other than "Normal" and "Widescreen".
I can atleast play 1920x1080 just fine.
You can also change the resolution in the registry (same for all the source mods aswell).
Even if it does work, CS 1.6 only supports Vert- in widescreen, so you'll actually be seeing less.
