Couldn't reformat pc, brought pc to shop...
Shince getting pc from shop, pc is generating loud running/clicking noises, and running slow. Anyone got any ideas?
First of all, get your money back.
You didn't really give enough information in your post, but your hard drive could be dying.
yea....go bring it home....youll probably end up with better support from this forum for free than you will from a foolish guy who, your paying $75 an hour to look at it.........
Could be anything really. Anything with a moving part can make clicking noises.
Lets run down a quick list of "clicking noise" causes:
Maybe he plugged the floppy drive cable in backwards, and the drive is in constant read/write mode.
Maybe a fan is going bad?
Could be a bad hard drive.
I fixed it.
floppy drive cable was not plugged in after getting it from the shop >:eek:
My mobo isn't fryied is it?
If it's running ok now with the floppy plugged in? What makes you think the mobo is fried?
Plug it back in and pray!!!!
It is well known that not putting enough stress on your motherboard can damage it due to idle cycling of the current. j/k :)
Was the cable hitting a fan or something? I would bet on hard drive noise. Run scandisk on it just to make sure. Might point to a problem developing.
Open the side panel, shut of all other sounds but your PC. Listen to it idle while in the bios for a while. See if you still hear it, then exit and listen to it boot into windows Watch the CPU and other fans spin up. Try a different HDD, and or new ide/sata cables to narrow it down.
