Could you please build me a $1000 comp
LcTheBeast
$1000 :D - light gaming, web browsing, email
nothing too fancy :p
- flat panel 17" or 19"
-wireless network card
-cdrw
-dvd rom
tnx tnx ;]
give me 10% of the cost of the computer...
nf7s
2400xpm
some muskin
some other stuff...
I think you better throw out the flat panel 17" or 19" first of all. Your not going to have much room in a $1,000 budget PC for an LCD.
Are you going to be overclocking quite a bit?
AMD Athlon Barton 2500+
Asus A7N8X or Abit NF7-S Motherboard
1GB Mushkin PC3200 lvl 1
LiteOn 52x32x52x CD burner
LiteOn 16x DVD-ROM
Get yourself a good 17" or 19" CRT monitor from Viewsonic or NEC.
Your on your own for a wireless network card. Linskys are probably the best i'd say though.
Do you have a case and power supply for all this already? If not get yourself an Antec case that comes with an Antec PSU.
yeah, skip on the flat panel. in that price you would either waste the graphics power on a low end flatpanel that would be able to show you all the frames. or spend so much on the flat panel your pc wouldnt be able to use it.
but i could try
If you're going to be doing any gaming, you're going to need a halfway decent video card, and that is going to cost at least $150, more like $200. And a decent 17" LCD is going to run 350-400, while a nice 19" monitor is going to run only around $250 or so.
Get at least 512MB of RAM and an 80GB hard drive. The 80GB shouldn't cost more than $60 or so if you get a rebate at one of the department stores like Best Buy.
Happy shopping.
I could barely keep within a $600 budget for HydroSqueegee earlier today with demands for Windows XP home and a monitor, and now a $1000 build requesting monitors that cost $400 - 500+ or even 700+?
Unless you want 2 generation old parts to go with that nice LCD, I'd suggest ditching the LCD idea and picking up a CRT. Cheaper, saves you hundreds.
AMD Barton 2500+
Abit NF7-S or Asus A7N8X
512 MB Mushkin Level I PC3200 (I don't think they have PC2700)
Lite-ON Combo drive
Radeon 9600 Pro
Whatever case you like
Western Digital 40 gig or 80 gig drive
Whatever wireless card brand made by the company that you own the wireless base from. That's usually the best way to go.
You never specified 'light gaming,' so I'm just assuming you won't need high end graphics anyways.
And that's a system. Plus get a monitor.
LiteOn 16x DVD-ROM
Not to judge anyone off a post, but if the dude can't put together his own system, I'd wager he's not overclocking.
I customized you a Dell with some great parts (they have some free shipping and other deals right now).
Dell Dimension 4600
3.06Ghz P4 w/ HyperThreading
512MB Dual Channel DDR
17 in E172FPb Flat Panel Display (Dell LCD's Rock)
128MB DDR NVIDIA GeForce FX 5200 Graphics Card with TV-Out and DVI (Because you were only going to do light gaming)
80GB ATA Hard Drive
16x DVD-ROM
48x CD-RW
All for $1,058 (shipping is currently free)
Yea on second thought i'll recommend that you order a Dell or HP machine and customize it online to suit your needs. With an OEM machine they will take care of you if anything goes wrong and will replace all the parts themselves. Alot of the time when people ask for someone to build them a complete system they dont know enough about what their doing.
From what you described you were going to be doing with the PC you dont need a high end custom built. A Dell or HP OEM will work great and probably save you some money.
Go read some guides and check out the top hardware listed on hardware sites if your interested in doing it yourself. Even mags like MaximumPC and PCGamer list low, mid, and high end systems and all their parts.
