Could you help me decide?
larrys2006
I am looking for a hard wired no wi-fi router but I do not know what specs I need to look for, I will get the 50 meg Verizon fios to start and I will run cat 6a to the ont either port. I use bittorent so I will have a lot of simultaneous connections maybe 250 or more and watch vids. I am looking at these units but I do not know what is the most reliable and easiest to configure.
EdgeRouter Lite3
Key features:
3x Gigabit Ethernet interfaces
Dual-core CPU MIPS64, 500MHz
Performance 1000000 pps
Intuitive WEB and CLI management interfaces
Support fro RIP, RIPng, OSPF, OSPFv3, BGP4 routing protocols
IPv6 enabled
VPN IPSec, PPTP, L2TP, OpenVPN
Specifications
Hardware Specifications:
Dimensions 197.52 x 91 x 28 mm
Weight 289.2 g
Power Input 12VDC, 1A Power Adapter (Included)
9 to 24V (Supported Voltage Range)
Button Reset
Processor Dual-Core 500 MHz, MIPS64
with Hardware Acceleration
for Packet Processing
System Memory 512 MB DDR2 RAM
Onboard Flash Storage 2 GB
Certifications CE, FCC, IC
Wall-Mount Yes
Operating Temperature -10 to 45°C (14 to 113°F)
Operating Humidity 90% Non-Condensing
Layer 3 Forwarding Performance
Packet Size: 64 Bytes 1,000,000 pps
Packet Size: 512 Bytes or Larger 3 Gbps (Line Rate)
LEDs Per Port
Serial Console Port Power
Data Ports Speed/Link/Activity
Networking Interfaces
Serial Console Port (1) RJ45 Serial Port
Data Ports (3) 10/100/1000 Ethernet Ports
Software Sepcification
Dimensions 197.52 × 91 × 28 mm
Weight 289,2 g
Power supply 12VDC, 1A - PS included, supported current 9 to 24V
Buttons Reset
Processor Dual-Core 500 MHz, MIPS64 hardware packet processing acceleration
System memory 512 MB DDR2 RAM
Non-volatile Flash memory 2 GB
Certificates CE, FCC, IC
Wall-mount yes
Operational temperature -10 to 45°C
Operational humidity 90% non-condensing
Layer 3 performance
Packet size 64 Bytes 1,000,000 pps
Packet size 512 Bytes or more 3 Gbps (Line Rate)
LEDs Per Port
Serial console port Power
Ethernet ports Speed/Link/Activity
Interfaces
Serial console port (1) RJ45 Serial Port
Ethernet ports (3) 10/100/1000 Ethernet Ports
info
RB850Gx2
The mikrotik RB850Gx2 is a five port Gigabit ethernet router. Comparing to the RB450G, the RB850Gx2 is much faster, with a dual core CPU, yet it still retains the same form factor, and will fit into the same enclosures.
The device is powered by a 533MHz P1023 PPC CPU, and also includes a temperature sensor and voltage monitor.
Product specifications
Details
Product code RB850Gx2
CPU nominal frequency 533 MHz
CPU core count 2
Size of RAM 512 MB
Architecture PowerPC
10/100 Ethernet ports 0
10/100/1000 Ethernet ports 5
MiniPCI slots 0
MiniPCI-e slots 0
Number of USB ports 0
Memory Cards 1
Memory card type microSD
Power Jack 2
802.3af support No
Supported input voltage 8 V - 28 V
PoE out No
PoE in Yes
Voltage Monitor Yes
PCB temperature monitor Yes
CPU temperature monitor Yes
Dimensions 90mm x 115mm
Operating System RouterOS
Operating temperature range -60°C .. +70°C tested
License level 5
Antenna gain DBI No
Current Monitor No
CPU P1023NSN5CFB
Max Power consumption 8W
SFP ports 0
SFP+ ports 0
Number of chains 0
Serial port RS232
I do not know and even I tried to ask verizon they either did not know or want to answer to a non user.
The ERL will be easier to configure of the 2 and neither will be as easy as a higher end consumer router.
You need to look up that first otherwise you're wasting your money...
