samborarocks
- Sep 8, 2005
Hi all,
I'm running the machine in my sig. I'm having a problem with a brand new install of Win7, where when I boot up the FIRST time (after say 8-24 hours), the splash screen resolution is set to something like 800x600 at the splash screen. If I login, my desktop resolution is the same. If I don't login, and instead just click restart, the box reboots and the resolution is fine (1920x1080). I can't seem to figure this one out. It's not unmanageable but, a little annoying. Anybody else have this issue, and if so, how did you fix it?
Thanks for any help,
SR
SR
