could this be done?
Why not buy a Scythe Kama Bay?
Comes in black or silver
do you think the black one would still look good in my case?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185020
my case
http://www.newegg.com/Product/Product.asp?Item=N82E16811133154
will this fan cool my system better then the thermaltake hd bay? im mainly trying to get airflow over the ram but i dont want to buy a ram cooler.
also how do i get to use the 4 pin connector do i connect the two mobo connecters toghter?
it it easy to replace the fan, i want to put a blue led fan.
does it come with screws?
and which of these blue leds matches the ones in my case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999122
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999127
i doubt i will buy the blue led fan now because it brings me from $68 to $82
sry for the early bump but im hopeing to buy my stuff 2night and need som awnsers.
Yeah, i think it would look good in your case, it will cool better than the hdd bay and i think the first links leds match better.
