Event Type: Warning
Event Source: Disk
Event Category: None
Event ID: 51
Date: 11/30/2006
Time: 7:10:55 PM
User: N/A
Computer: THE-PUNISHER
Description:
An error was detected on device \Device\Harddisk1\D during a paging operation.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 03 00 68 00 01 00 b6 00 ..h...¶.
0008: 00 00 00 00 33 00 04 80 ....3..
0010: 2d 01 00 00 00 00 00 00 -.......
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 0e bd 64 0c 00 00 00 ..½d....
0028: 2b 03 00 00 00 00 00 00 +.......
0030: ff ff ff ff 03 00 00 00 ÿÿÿÿ....
0038: 40 00 00 84 02 00 00 00 @......
0040: 00 20 0a 12 40 03 20 40 . ..@. @
0048: 00 00 00 00 14 00 00 00 ........
0050: 00 00 16 00 a0 e6 11 86 .... æ.
0058: 00 00 00 00 98 12 11 86 ......
0060: 02 00 00 00 87 5e 32 06 ....^2.
0068: 28 00 06 32 5e 87 00 01 (..2^..
0070: 00 00 00 00 00 00 00 00 ........
0078: f0 00 0b 00 00 00 00 0b ð.......
0080: 00 00 00 00 00 00 00 00 ........
0088: 00 00 00 00 00 00 00 00 ........
Sometimes my system boots up very fast. Most of the time, however, it takes several minutes. I'm running XP Pro SP2. I've noticed that when it takes a long time to boot up I have several (~20) events like the one above in the event viewer. Now, drive "D:" is my optical drive (DVD+-RW), but hard disk 1 is my boot drive (Seagate Barracuda 7200.9 ST3160812AS 160GB 7200 RPM SATA 3.0Gb/s). Is this likely to be a software thing, or a problem with the hard drive? If it's the later, should I just try and RMA the drive? If I do replace the drive, can I image everything over to a new drive so I don't have to format, or am I stuck?
I'd appreciate any help, thanks.
[edit]Forgot to mention, I've defragged and ran chkdsk. Also, the mobo doesn't report any SMART errors.
