- Apr 24, 2008
Hello fine folks.
As per the title, I need help replacing some system fans in my PC. My goal is to maximize cooling efficiency without maximizing noise levels. I usually alternate between running all fans in high speed for gaming, and low speed for regular tasking/netflix etc. I'm not happy with the Phantek fans I've had for a long while right now in terms of noise. One of them I think is defective and makes more noise than the others as well.
What I have to work with:
A 5-port, 30-watt per channel, 5.25" bay fan speed controller. It has 3-pin connectors. Link for Specs here.
Case is a Fractal Design R5.
What I need:
2 x120 mm Fans to mount on a Corsair H100i GTX (Exhaust out of the top of the case). I have no idea what fans are good for radiators anymore.
4 x 140mm Case fans configured as 1 x 140mm for rear exhaust, 2 x 140mm for frontal intake (filtered), 1 x 140mm for side panel video card intake (filtered)
Thank you in advance for your input.
What I need:
