1Wolf
- Jul 10, 2007
Hi everyone,
I'm in the process of re-building/making some changes to a system I built a few months ago and was hoping I could get some advice on configuring my drives. I've just finished reading the information I could find in the "Answers" sticky on hard drives, and the way data is stored, and followed several links about partitions and such. Its alot of information to digest and I'm doing my best here...so I thought I'd ask for some advice.
This machine I'm building is primarily used for gaming, and also for work. As such, I'll need to set it up for Dual-Boot Windows XP Pro and Vista 64 for just a little while. Eventually the Windows XP Pro partition can go away.
I've got 3 HD's as follows:
1 10000 RPM SATA 150 Gig Western Digital Raptor
2 7200 RPM SATA 320 Gig 7200.10 Seagate Barracudas
How would you set up your drives/partitions?
I'm thinking that I should definitely put Vista 64 and XP Pro on 2 partitions of the Raptor...and that I should place their associated "Program Files", games, programs, etc. there as well.
That leaves the 2 7200 RPM drives as storage drives.
I've got between 4 and 8 Gigs of memory (I say between 4 and 8 because I haven't decided if I'm going to put the extra 4 I have in this machine to have a ton of memory in my gaming machine, or if I'll put 4 Gigs of the memory in another machine here....most likely...I'll put all 8 in my gaming machine)....
Any advice on how I should setup my page file? I've read lots of posts about that as well...but its difficult to determine how mine should be setup when most of the posts I read seem to refer to days when 2 Gigs was a 'ton' of memory..and most folks had 512 Megs or a gig.
Where should I place the Swap File? Should I just leave it on C:/D:, on the Raptor in the same partition with the respective operating system (One for XP on C and one for Vista on D)? I'd read that its a bad idea to create a separate partition for the swap file on the same physical drive as the OS....so I'm guessing its better to either just leave the swap files on the partitions with their respective operating systems...or...place them on a partition on a separate physical drive....even though that drive is slower.
Or would I be better of creating a partition on one of the 7200 RPM drives and placing the swap file there?
I've read stuff about "Channels" that was mostly referring to IDE drives...previously...I'd just let the BIOS auto-detect my drives and set it up as the BIOS saw fit....but I'm thinking there is probably a better way to do that. Should I set those 3 SATA drives up in any special "Channels" or what not (For reference, my mobo is an EVGA 680i).
If you've any other advice or suggestions on configuring/partitioning those drives/swap file...that'd be terrific.
Thanks!
Thanks!
