Coldblackice
- Aug 14, 2010
I have a WD Red 3TB drive that's recently been causing problems, with event log saying it's not responding within the timeout period (when I was using Intel's controller driver), and now "The driver detected a controller error on \Device\Ide\IdePort1." (now using Microsoft's controller driver). However, SMART values look completely fine. I also did a chkdsk on it and found no errors or problems. It just hangs for a while, then suddenly "goes" just fine.
I've swapped SATA cables, tried different controller ports, and removed the Intel ICH10R controller driver and reverted back to Microsoft's -- all to no avail. It doesn't seem like "typical" dying hard drive platter symptoms -- it'll hang for a while trying to access it, but then it'll begin transferring data, and doing so just fine, at ~100MB/s.
Could there be any funniness happening with its partitioning, given it's a GPT partition on a non-UEFI system? Could alignment be an issue? Any particular software I could use to check for problems?
