Could a bad flash render the power button useless on a laptop?
Staples
I am looking at a laptop that seemed to be on its last legs. I decided what the hell, I will flash the motherboard and see if it helps. It is a cheap HP laptop that is 2-3 years old. I downloaded the flash file and it was a window program. When I ran it, there were 8 blocks it had to flash. The first seven where flashed and when it was on the 8th, the computer rebooted. I will assume it finished but I can't really verify. I wanted to get into the bios menu but before I know it, the computer was loading windows. At this point I turned off the computer and tryed to turn it on again. The power switch does nothing. If I plug it in, the LED that indicates such goes on but that is about all.
If infact this was a bad flash, is it even possible that the power switch would have no effect? I just assume that this was a cooincidence that that computer totally died right after I flashed it but the cooincidence is just very strange.
Right now I have a brick that will not even turn on but I don't think this could have been caused by a bad flash.
For sure. When that happens the only solution is to order a new BIOS chip and upgrade the BIOS that way...
My laptop is doing this now too. It started a few days ago. It has done this from time to time. Its on its last leg. Make sure you remove all power form it. And if you can find the CMOS, clear it.
I will try clearing the CMOS for all it is worth.
Getting this damn thing open is proving to be quite the challenge.
