one of the cosmos is narrower than the others. that's all I know.
Nope, go with what works. Get a stacker.
Newer version?.....
Well couldn't I just buy a 300mm fan and put in on the side of the Cosmos 1000?
And for the 250mm fan, I wouldn't need to cut a hole, I just could mount in on the inside, right?
^Thank you. So Ravynmagi, they took the HDD bays out of the Cosmos S?
I'm not really impressed with the Cosmos S case.
They had a good thing started with the original Cosmos 1000. I have one and enjoy it. Though it isn't perfect. But the purpose was to provide decent cooling in a very quiet case. They did great with the quiet. They needed to fix a few things with the cooling.
But instead of finishing what they started, they just gutted out the entire original Cosmos interior and replaced it with a Stacker interior. Gone are the very easy and convenient hard drive racks. The sound dampening insulation. And other small touches that made the original Cosmos.
Now it's just a another Stacker model with a Cosmos exterior. Personally I think the Stacker exterior looks better. *shrug*
I was really hoping Cooler Master was going to fix the original issues with the Cosmos while keeping it quiet. Replacing the steel frame with aluminum. It doesn't need a giant fan, but really the hard drive fan mountable below the hard drives for more direct cooling of the drives. Really just those two things, weight and poor hard drive cooling, would have made a major improvement to the case without sacrificing sound dampening.
Yup its goneI think they did. Not sure though. Maybe someone can clarify.
