Ok here is my simple work log some of it is older but there have been a few updates.
This is copied and pasted from another forum.
First lets start with what I had....
Case: Cooler Master Cosmos S
Motherboard: Asus P6t-Deluxe
CPU: Core i7 920 @ 4Ghz
Memory: Patriot Viper DDR3 3 x 2GB @ 1600Mhz
CPU Cooler: Cooler Master V10 with 2 Yate Loon D12SH-12 120mm Fans
Video Cards: 2 x EVGA 8800gts(G92) 512mb
Sound Card: Creative X-Fi XtremeGamer Fatal1ty Pro Series
Hard Drive 1: Western Digital Raptor SATA 3.0 300GB
Hard Drive 2: Western Digital SATA 3.0 250GB
Hard Drive 3: G.Skill Titan SSD SATA 3.0 128GB
Power Supply: Thermaltake Toughpower 700watt
Now here is some new stuff
I also have some left over water cooling parts from my first build so combined hopefully I end up with a snazzy setup. Final specs here:
Motherboard: EVGA X58 Classified
Memory: Patriot Viper DDR3 3 x 2GB @ 1600Mhz(Going to purchase Domminators)
Video Cards: 2 x Asus 4890 1gb
Sound Card: Creative X-Fi XtremeGamer Fatal1ty Titanium
Power Supply: Enermax Revolution85+ 1050watt
Watercooling:
CPU Block: Heatkiller 3.0
Radiators: Swiftech MCP320(looking to replace),XSPC 240.
Pump: @ Swiftech 355
Res: XSPC Dual Bay reservoir for 2 DDC pumps
Fittings: Bitspower Compressions
Tubing: Primochill LRT
GPU Blocks: EK Acetal+Nickel 4890
Whole bunch of Murder Mod Sleeving!
So here is a pic with old mobo and CPU cooler and New cards and PSU
OK so I started sleeving but I ran into a little issue. I made sure to get the EVGA Classified part 760/761 because I heard no issues with Rev85 PSUs. However low and behold I am having issues. So I'm getting an RMA from Enermax. So sleeving put to the side...
I guess lets move on to the case and get it prepped....
Say bye bye plain ol' case!
So instead of sharing with you another pic in the midst of me taking it apart, I'll share with you a reminder....
WEAR GOGGLES!!!!
That is a drill bit that snapped in half while removing rivets. Thank JEEBUS I was wearing goggles because it came flying at my face.
OK so here are some pics of the case...in a box...
And here is a pic of the bottom panel with a 240 rad hole cut out...and one of the motherboard tray with a cable management hole cut out.
picked up the case from the powder coaters...so glad i went with the wet black over the flat black. The X-Fi is there to show the reflection...
Bare with me here I just got a new camera so hopefully these come out ok.
First up new D0. Good friend at Microcenter had this on hold for me!
Man its hot in here I wish I had a fan or two....
Its coming together
This dual bay res with DDCs is nice...easy to use...could use some more room for the pump wiring though.
Oscar approves. Its time for leak testing...
Currently its up and running. However the cabling needs some work, looks like i'll have to cute some more cable management holes in the Mobo tray. Also I got a new Intel X25m Gen 2 to play with
I have it drained and I'll be dremeling out some more holes and I'll be re-plumbing it.
I also got UN designs to help me out with a new faceplate...
here is a render...
Watercooling:
WEAR GOGGLES!!!!
Its coming together
here is a render...
