Cosmos S clear side panel
Does anyone know where to find a Cosmos S clear side panel? If so i would appreciate the link. Heres the case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119150
CoolerMaster on their Web site indicates that there is an optional clear window for the Cosmos S, but I could not locate any info other than what is said here:
http://www.coolermaster.com/products/product.php?act=detail&tbcate=168&id=3948
I prefer the larger window that Coolermaster showed at a recent computer show instead of the smaller window at Performance PC.
MikeSp
I wish they sold a solid (same brushed aluminum finish) black panel that looks just like the other side.
If anyone is going to carry this in stock it will be these guys:
http://www.performance-pcs.com/cata...th=158&zenid=0698b0ff1c50b18171fa7c701db09d43
It appears that they do not sell the panel by itself, but you can buy the whole case with the "windowed" panel now through them here:
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=194&products_id=23721
Black Window for Cosmos
Silver Window for Cosmos
And with the pulldown options, You can select a large window and other things such as a 80,92 or 120mm fan hole.
