Cosmos 1000 Liquid Cooling
Showtimextx
Does anyone know where I can look to see how big of a Rad I can put on the roof of the case?
do you own this case? if you do get a tape measure out. beyond that look up their website, i'm sure all manufacturers list case dimensions.
im working on doing a watercooled Cosmos 1000, you can fit 1 -120x2 in with no mods if you put your optical drive down you could put a 120x3 but it would require a little dremel work on the top of the case, it would still vent through the diffuser on top that directs the top vent airflow towards the back of the case.
Nice work so far Headpunter, I will be following your work. I just ordered the Cosmos 1000 and was looking for what could be done with it.
yeah i just stripped mine apart and i need to update my worklog, finishing the build is taking me longer then expected....
